If I was to build another setup...
  • 6
Double barrel bass cannon nice I like the colors to. I'd do something a little more capable than the e series though.
Lol i like how the subs are loading off nothing and just shooting out the ports. I did a box just like that with sa 10's and they were loading off each other. It didnt load off anything in my trunk car and ******. If you can get it to load the subs it would probably be decent.
Quit talking nonsense and acting like you know something... It's ok to be new...ask legit questions and you can get legit help...but right now...
152
Don’t do it on the ground wire. If you lift the amps main ground and the amp tries to ground through the RCA cable shield, you can damage the head...
14
Check for a blown fuse (or fuses). Referring to the car and not the amp. How do you have the amp wired? Power is directly to battery and ground is...
16
728
RangerDangerV2
RangerDangerV2
st cloud MN
hispls
slater
    May 2, 2024
slater
    May 2, 2024
