Upgrade consideration
  • 7
JoeK
Ringtown, PA
Currently im running 2 SPLAudio built 12s rated at 1500w rms each running on 2 SK-1500.1Ds wired at .5 each amp. box is 4.6cubes @ 30hz
I dont think these woofers (built with 3' 4-layer coil on DAD BD motors) can handle the power they are getting at .5ohms so im considering the following two options:
(a) Upgrade to 2 beefy 2k-2.5k rms 12s and drop them in the current box
or
(b) Get a single beefy 3-4krms 15" woofer and wire them off the skars strapped at 1ohm? Assuming proper box size comparable to the one i have now.
Right, i just dont want to lose output. I have cone area with the 12s but the motor force of something like the SSA evil or SP4/Team would be more than 2 twelves of lesser sort
Single 15s im looking at:
SSA Evil
Fi Team/SP4
DC Level 5
Dual 12s im looking at:
Orion HCCA
DC XL
AA mayhem
Sundown X/ZV4/ZV3
SSA Evil
Fi Team/SP4
DC Level 5
Orion HCCA
DC XL
AA mayhem
Sundown X/ZV4/ZV3
Mayhems .. Or a single evil would be nasty //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Hello, I have a Peugeot 207 SE 2007 and would like to upgrade its existing car stereo. It’s a single cd fm/am radio and I would like to get...
That's not an amplifier designed for subwoofer use, it's a 4 channel designed for you primary speakers. Small $75 investment to get you where you...
396
i would not worry about the tweeters. They will never see anything above 20 watts before your ears bleed. your options with 4 channels would be...
509
Thought I would update this thread… Couldn’t login over the weekend for some reason. Finally got the Kenwood installed last Friday… Had a little...
32
Are you planning on upgrading the alternator and add extra batteries?
730
JoeK
JoeK
Ringtown, PA
mylows10
Brendon Jenness
    May 8, 2024
    May 8, 2024
