07 lucerne + 2 type R's
  • 5
noble brown
im about to build my box for two 12" type r's in a 07 lucerne. settled on a 3.5 cu ft @ 32hz. just curious if anyone has any experience here on what will work best in this build: speakers up ported back, speakers front and port back or both to the back. thx
i've built probably over 40 boxes for the 12" type R. the box will perform if it is bigger. 2 cubes per sub if running lots of power (like a 1000rms or more) and 2.5 cubes if running less power. tune it to 34Hz. use a single 4" flared port per sub. on paper this isn't enough surface area but the type R's like it this way. for the two speakers you could also run a single 6"-- more expensive but generally a 6" outperforms 2x 4".
I agree with everything, except tuning. They do like 2-2.5 cubes. I like mine tuned to 32, but I've seen 30-36 work well actually.
it is a matter of preference of course. 34Hz seems to be a good balance between playing loud and getting low.
so i built a pretty standard 2.2 slot ported box. speakers up and port to the back ( i have a autoCAD 3D file of it but cant figure out how to convert file to post) and it made a world of difference. at specs these 12s were suffocating.
You only made the box 2.2 cubes for 2 12s? That's way too small for a ported box. It should be 2.2 cubes for each sub
The Type R subs are a really great sub. Deff ask about a DMM reading or take a DMM and check them. Dust Caps can be replaced as stated and...
118
Dammned that looks awesome. be a great picture in a workshop!! I have maybe 6 steel ratcheting type clamps, if that. much like the ones you have...
408
If you want something weather resistant, get a marine amplifier.
noble brown
noble brown
Hermitage, pa
noble brown
    Apr 26, 2024
    Apr 26, 2024
