FS: MTX RT-X02A crossover
crx4luke
Selectable on or two inputs that can be changed to 3 outputs. In good condition 7/10
$35 shipped
Included in CONUS
Thanks buddy! Given me a lot to think about in terms of what to do; I've been watching YouTube videos on this stuff all day as well so I really...
670
You can wire those subs up @8 ohms if they are both SVC4 ohm subs,and that amp will run fine after being tuned properly...
The 240 should be 2x40/ 2ch. rated at 11.9v. Should generate close to 50+ @14v rms. Only Rated @4 ohms bridged Mono.. Should be around 125 rms...
In 1990: The MTX MTA 225 had a MSRP of 549.95 25x2 0.02% THD S/N 102 12x 8 1/2x 2 3/8 The MTX MTA 250 had a MSRP of 649.95 50x2 0.02% THD S/N...
12db is usually 180° out of phase if used left and right. 24db makes the full 360° phase change when running left and right. This is...
155
crx4luke
crx4luke
Jacksonville, FL
ewadz3006
GoldCountryCA
    Apr 26, 2024
GoldCountryCA
    Apr 26, 2024
