On a budget. Need 6.5 mids, 6" woofers and amp
tipnitty
TH^T GUY
984
St.louis
Bought a trans am for daily driver car and only the highs are working. Previous owner removed the stock monsoon system and the speakers. So I need a set of 6.5's for the doors. 6" subs for the rear sail panels, and looking for an amp to run all for. Let me know if you have any of these.
Amp needs to be small so it can be tucked away easily. Thanks.
I did a system in one of those cars with a Massive Audio NX4 mounted in the space where the factory amplifier was mounted, CDT Audio HD-62AS components in the front and CDT coaxials in the sail panels. The CDT HD-6MDVC 6.5" subs are designed to directly replace the factory Trans Am subwoofers. What's your budget?
Budget is pretty open. I don't need absolutely the top of the line products. But if you have had positive results with that set up, shoot me a price. I would definitely want to keep the amp in the stock location.
You're going to need to add sound deadening materials. I recommend sounddeadenershowdown.com. That's one thing I regret not doing on that build, plus the "stealth" 10" subwoofer box just did not get loud at all. I was restricted to using that box per the customer's need to keep the T-tops storage.
A pair of American Bass Hawk 15s will slamm home as well. Just put in a pair in a good friends 02 T.Car in 7.0@31htz on a Cresendo Skyway 3k...
29
It depends on how cheap you wanna go but I've had excellent results with a 12inch power acoustic gothic sub in a small sealed enclosure for budget...
72
8K
827
Oh come on! Why'd you have to go and tell me the price? Now I'ma start eyeballing them.
tipnitty
TH^T GUY
tipnitty
St.louis
zinda
    May 22, 2024
    May 22, 2024
