Amp Question
  • 2
Depends on what kind of power the sub needs, but simple answer is yes, at 3 ohms.
My friend has a JL W7 and his amp bit the dust so we were wondering if it would run fine off of my amp? I think the W7 is like 1500 rms, correct me if I'm wrong.
Hell... Run It.. You will be ok @ that Ohm load(2.67). Just dont go below 2ohms and you will be fine. 2ohms is the lowest stability of that...
5
If you do use speaker baffles.. I recommend the plastic ones rather than the foam ones, and drill a 1/4" hole at the bottom of it in the back for...
9
Haven't 100% landed on which one, but I am down to those two
12
That makes sense. I took it apart today. It doesn't look too impressive but it should be better than the head unit. I'm going to install something...
8
03Bonneville
03Bonneville
Lincoln, NE
03Bonneville
Chris Gerrish
    Apr 25, 2024
Chris Gerrish
    Apr 25, 2024
Latest topics
