crossover building?
  • 3
k_schutte
Hoping someone can help me out on this. I've got a design for a crossover, I know the crossover point is correct and it will work but I wanted to add a low pass filter as well for my mid so I was wondering if anyone could verify this for me? Basically, I just need to know if "C3" (the "bass blocker") will work in that position?
To clarify, C1, C2, L1 and L2 are correct and would make a crossover, simple enough. I need to know if adding the "bass blocker" (C3) where it is will function properly and not mess anything else up...?
Not quite. What you have there is effectively still a second order low pass filter (but not quite because your added cap is doing high pass work, so in theory it is working like a bass blocker. This is not, however, the way to design what you're wanting.). At high frequencies, capacitors become shorted and inductors create an open circuit. At low frequencies, inductors create a short and capacitors create an open circuit. This is why if you look at your high pass filter, you have a capacitor and a parallel inductor and on the low pass originally was a series inductor and a parallel capacitor. What you'll end up with even if you switch out the inductor is still just a low pass filter, albeit 3rd order. What you're trying to make is a bandpass filter which is instead a parallel inductor and capacitor or a series inductor or capacitor (the latter is more appropriate for high-fi audio as putting anything in series with the driver introduces its effects to the resulting signal. If you have very high quality caps and low DCR inductors, then the series approach works fine). A combination of both types creates a higher order filter. Hope that helped some. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
12db is usually 180° out of phase if used left and right. 24db makes the full 360° phase change when running left and right. This is...
155
On another note, if you're competing in SPL, you might want to check around at what the best crossover point is. These two drivers (your 6.5s and...
8
893
I usually cross at 80hz And as a drummer The meaty end of a kick is 40hz..like bands such as Metallica 50hz is a U2 kick
9
k_schutte
k_schutte
cedar rapids, IA
keep_hope_alive
GoldCountryCA
    Apr 26, 2024
GoldCountryCA
    Apr 26, 2024
Latest topics
