Custom SPL built Alpine Type X 10
  • 6
ace_800
Custom built Alpine Type X sub built by SPL Audio
Used for about 9 months run off my Exile at 2 ohms. From what I remember being told it has, its a type X mag with copper cooling coil, duel spiders, sewn leads and riser. I believe it has 1 or 2 more things done to it, but don't have the text from SPL with how it was built. I had it taking 1500rms daily and close to 1800rms on burps, if what Exile says the amp does is correct. They actually said 2k @ 2ohm and 2400@1, I feel its closer to 1800rms. Sub is in excellent shape, no damage except for some scratches on the mag. This sub will get low. Recommended box is 1.3-1.5^3 tuned to 32-35hz. Its a Dual 1 ohm
175obo shipped
Included
Absolutely. I am always learning and think it's probably impossible to stop learning. I appreciate the advice and don't doubt for a second the...
56
4K
  • Locked
15" Custom Sub Dual 1 ohm I've had it running off 2000rms in my daily. I'll include the box if you're in SoCal for pick up, Dimensions are...
ace_800
ace_800
Okinawa, Japan
Skoty422
    May 10, 2024
3toneEYZ
    May 10, 2024
