Best thing to use
Below20hzonly
Ok so i have literally no tools at all that involve cutting wood besides a table saw. i was wonder what is the best thing to buy that is really good for cutting out sub/speakear cutouts, like for 10" subs or 6x9 speakers,etc.i just have no clue, other than really expensive shyt like at shop class back in high school. thanks
Yep, a jig saw can be had for very little..But for an all around tool to do cut outs on doors /wood/grinding ect for detail...Dremel or my favorite RotoZip:cool:
Dremel Trio
Uhh, Dremels **** at cutting through wood. For the price of what one costs you could get a router (which I don't recommend unless you plan to make a bunch of boxes) which would be 10x better. The Rotozip is better (but not much), unless you plan on using either the Rotozip or Dremel for other uses, they wouldn't be a very good investment. Plus the bits are very lame and small. A jig saw works fine. It's cheap, the blades are cheap, and it does the job.
Avoid jvc 480bhs hard to see the display in the daytime even with the brightness all the way up also not as easy getting to the audio menu like...
5
590
Not good for introducing new guys to lithium Lots of burned down cars from user error because the tech is new and people are ignorant.
24
low level when using RCAs so that knob should be pushed out. The crossover turn it all the way right and use the one on the head unit and set it...
5
899
Below20hzonly
Below20hzonly
East Grand Forks, MN
wenn_du_weinst
Chris Gerrish
    Apr 25, 2024
Chris Gerrish
    Apr 25, 2024
Latest topics
