Remote bass control knob for SD SAZ-1500d v2
  • 2
Those look like decent cheaper options for sure and probably fine for some systems, but I agree, Audiocontrol has been making high quality stuff...
654
I'm not familiar with Vertigo amplifiers. If they have a master-slave setting, you only need one gain. otherwise, @dragon.breath nailed it.
997
Is there an external fuse mounted near that amp going to it? If so, make sure it is not grounding out some how. Frayed wire touching ground or...
Usually when you shop for a replacement harness for your model, you will find the pictures may show you in what pins your wires go to.
Flex68
dilligaf
Flex68
The Backroads
Flex68
    Jun 3, 2024
