Tuning an enclosure?
No it will be able to play below that frequency but the response will be reduced because of the rolloff.
Check this picture for an example. Those are a few different response curves, different tuning frequencies will offer different peaks. Generally when you tune higher you get a larger peak which is good for SPL competitions but you rolloff faster so you miss the low end.
SQ is subjective. If you're looking for the flattest possible response curve, usually sealed will give you that in a car. Porting is more...
mopower440
mopower440
chapel, TN.
THATpurpleKUSH
Chris Gerrish
    Apr 25, 2024
Chris Gerrish
    Apr 25, 2024
