In need of an amp
  • 5
Andrew2006
i am looking to buy an amp for my two jbl P1224s they are dual 4 ohm and Peak Power Handling 1200 Watts RMS Power Range 400 Watts i have about $350.00 to spend on a amp so i am looking for a one ohm stable amp and which i do plan to upgrade to four jbl p1224s so i would liek to get an amp that i could find pretty easy to get for the other pair but lmk what you got need the amp pretty soon
Its more power than needed but its always good to have more than less. I ran it on a single 18" Fi btl @ 1 ohm daily and it straight slammed in my wall setup. Here is a video of it in its early stages powered by the xa-3000D
You would just have to tune the gain in properly. I have read it will do .5 ohms daily as well.
11
518
While we're speculating, why not bump up your volume gain (no pun intended) for just a few dollars more (literally) and go with the 8" versions of...
5
909
* The fuse at the start of the cable needs to be equal to or greater than the fuse/load at the end of the run. * The cable needs to be capable of...
4
Thank you for your reply. What if I wire in series for 8 ohm load ? Sorry for my newbie questions, but wouldn't it have better sound quality...
Andrew2006
Andrew2006
La Follette TN
BeAlLsTaR13
GoldCountryCA
    May 5, 2024
GoldCountryCA
    May 5, 2024
Latest topics
