couple of box questions
Neither is needed but 45s can help improve air flow. If they weren't incorporated into the original design than adding them in will take up room which could impact tuning but I doubt it would be noticeable. Unless you're running an insane amount of power, resin isn't necessary but again can help to increase rigidity.
I relocated the head unit ground, and I also put plastic wire loom tubing over the RCA cables since they sit on the bare metal floor under the...
12V is well within the range of acceptable voltage for most mobile electronics. How much power you're leaving on the table not feeding your amps...
The SIA is a great line of amps. People like to hate. My little SIA does work with 4-8's. And it bangs the lows.
23
6K
Yea. I literally spent 2 hours perusing the site. Got to love a helpful website. I bet that they have thought of everything that could possibly...
904
110
truckcap22
truckcap22
ky
on1wheel01
    Apr 26, 2024
    Apr 26, 2024
