Freq range and crossovers.
  • 2
JDBoogie
I have a set of Image Dynamics XS65's run off a JL 300/4 and a Audiocontrol DQL-8.
The freq range on the comps is 80 - 22000.
Does the "freq range" specify that the included crossover will not allow freqs lower than 80hz pass. Or does it mean that 80hz is the lowest freq that should be sent to the spkr?
No. The x-over only controls the blending between the mid and tweeter. It doesn't do anything on the bottom end of the woofer. 80Hz is probably the -3dB roll off point of the natural frequency response of the woofer.
The difference in 96 to 98 db is going to net you about an 22% difference in output, all things considered equal. When it comes to 325 per channel...
547
Yeah but accubass only restores the bass roll off. It doesn't take an incomplete signal range and make it a full range signal.
13
Okay, couple of suggestions With this being a sealed enclosure. Play with the position of the enclosure. Sub firing back, sub firing forward, and...
Hpf set to 80hz door speakers really shouldn't play lower than that without specific design inputs ie: sealed doors, fully deadened doors, mounted...
JDBoogie
JDBoogie
Round Rock TX
mvw2
Brendon Jenness
    May 8, 2024
    May 8, 2024
