How do I run amp with OEM Navi/OEM Amp?
  • 2
subydude81
NY
OK my cars a 2006 acura tsx with built in Navi and I have stock comps in front, 6.5s in rear doors then 6x9 subs in rear deck. I'm keeping the factory Navi so how would I go about running an amp to the front comps and rear 6x9s.
I have a 5 channel Hifonics amp but not speaker level inputs. I know of LOCs but since the wiring from the Navi goes into the factory amp i'm not sure how I would get enough signal for 4 speakers.
I'd like to just bypass the factory amp and run the 5 channel to all speakers, I know rear door speakers don't need the amp but might as well since I upgraded those rear door speakers.
Hmm a bit pricey. I don't mind spending the money but i'm trying to find a cheaper solution first if its possible. I don't mind the extra work that may come.
I'm running those in my pickup. There's no real "best amp" answer. You want something with really low THD, and 100-150w RMS per channel.
I recommend wiring to the 2 ohm load on the amp you stated you have, or you can wire to an 8 ohm load for amp stability. You can wire one sub to...
11
Just for examples sake regarding electrical, I have 1400 watts total between both my amps and my system has no trouble running everything max...
27
You should run all exact matching subwoofers in one singular enclosure and 1 amp or matching amps for the best listening experience for the space...
11
subydude81
subydude81
NY
subydude81
Mr FaceCaser
    Apr 26, 2024
Doxquzme
    Apr 26, 2024
Latest topics
