Kicker 12" L5 hatchback enclosure
THUMPPER
Pound That Sound
Very detailed work, sir. Nice job.
But did you add resin or anything to that bend next to the port to stiffen it up?
I would think that it will blow out if not //content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif
Very detailed work, sir. Nice job.But did you add resin or anything to that bend next to the port to stiffen it up?
Yes, he puts resin in it. That's why he drills the holes in the kerf to allow air bubbles to release.
Beautiful box once again thumpper.
I use the holes to take advantage ofcapillary attraction..the resin gets drawn in thru the
slits and the air bubbles come out thru the holes...
this ensures that the kerfs are 100% filled and rock
solid once the resin cures....
by the time I am done with the Kerf it is stronger than the MDF itself
Once again a nice box for sure. Your attention to detail and clean cuts have become your signature. I have two NIB 10" L5 that may have found a reason to be installed after seeing this enclosure!
Yep, that will mark the third iteration of teh X series. i figured that was in the loop as they have been running out of stock on the last...
11
355
Is this a blue or blue/white wire from the Kenwood? The ACC wire is red and although that should turn on the amp, it is not the prefered wiring...
low level when using RCAs so that knob should be pushed out. The crossover turn it all the way right and use the one on the head unit and set it...
5
894
Not all 3 have same issue. Was just giving an example of the issues Each one has its own issue Yes I did replace rca cables and swapped left and...
THUMPPER
Pound That Sound
THUMPPER
Salmon Arm BC Canada
BobbyDD
Chris Gerrish
    Apr 25, 2024
Chris Gerrish
    Apr 25, 2024
Latest topics
