Suggestions
  • 1
moorezy
I want to make a new box. the one i have no is being smothered by my trunk ( its too big ) its a slot port right now for four 12s ( pioneer TS-W1207D2 ) 81sq inches. I want to go with flare port to make some more room in trunk and just for the ease of build. I don't know whether to go with one 6" flare or two 4". I'm thinking of dividing the subwoofers in two separate chambers ( two in each ) just to prevent the turbulence acting against each other. Just want to know some ideas
front doors are subs...fyi Go with AudioControl 6x9 components up front and coaxials in the rear. You will be impressed with just changing to that.
243
If you can find these in your area. Id recommend these for drop ins. They play from 40Htz on up. Sound very nice on amplified power for premium...
You might get some inspiration from the install that I did... Delta Audio Install
673
Hahaha his brother got some from a friend. American bass amp and some alpine s 12in subs. From a buddy of his now Eastons chomping at the bit...
487
Thanks for the suggestions I will look at all this when I get home from work!
461
moorezy
moorezy
St. Catharines, ON, Canada
moorezy
Chris Gerrish
    Apr 25, 2024
Chris Gerrish
    Apr 25, 2024
