Made the box, now have issues...
etc.
car audio newbie
86
Midwest
I built a small slanted sealed box (~1 cube)) for a 12 inch Memphis PR, just to throw in the trunk of a 97 Crown Vic. It just sat in the bottom of the trunk on the drivers side.
It sounded better than I thought it would, but began building another sealed box to the exact specs (1.25 cubes) to place over the rear end and fire upwards into the rear deck. I have it bolted down and hits very mellow compared to the old box/ location. When I crack the trunk open ~3" in the rear I can tell a very noticable difference.
The sub is mostly on the drivers side, about 8 inches from being in the middle of the car...
I've read about venting the rear deck, but still unsure of where to place the vents: Over the sub, off to the side...? Or is the idea just to give it some air???
I plan on taking out the rear 6x9s and rear seat padding but I dont think that will very help as much. I've also thought about cutting out the cardboard material from the carpet, but havent taken a look to see if its glued to it.
I know its an up hill battle with a trunk car, but any help would be great //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
LOL thought about it, but due to the snow,
bags of salt > sub box //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
It was also a bad location for it. When ever you opened the trunk water/snow would drip on the box.
so put the old box in the new box's location? i have the same effect when i crack my windows down about 1-2 inches. has to be both windows tho.
Good idea //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
I could do that. I didnt really take the time to make it very pretty, just threw it together to have something while I took the time to build a more eye appealing box to correct specs lol
I will do the whole padding/speaker removal and see how it goes...
If not I will just re-install the ugly box and make a more pretty-er-er box and putting what I learned to good use //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Well after taking most of the seat padding and both rear 6 1/2 out, the end result wasnt good....sounded worse.
Old box goes in and a new plan has begun.
id eq at the db you listen to the most often. our ears dont hear things the same, at different volumes. why tune at 60 dbs, when you listen to 90
10
589
There is a good chance you could add some sort of Bluetooth or AUX input to a vintage stereo such as a 1978 Pioneer, maybe with a separate toggle...
610
I got to message a DD woofer builder a decent bit my last stent of box designing; they would send me designs to do for or with individual...
812
I feel the same way. I do wonder if the build of the stealth can handle the additional 200 w rms of power of the w6v3 since it will apply more...
895
etc.
car audio newbie
etc.
Midwest
etc.
DEW123
    May 7, 2024
DEW123
    May 7, 2024
