One of my check lights came on..
Thats the check engine light. Most likely a sensor gone bad. Check your oxygen sensor mass air flow sensor all tha stuff. If none of that fixes it try changing the oil and all of the fluids and if that still doesnt work you may want to take it in to get a tune up.
If its obd-1 you can check it yourself by grounding out two of the pins with a paper clip. I dont remember which ones they are tho. I will get back to you with that in the morning if you have obd-1. Let me know.
These are decent budget subs. The box design isn’t bad at 5 cubes for these, but I’d drop it down just a little and raise port tuning up to 32...
And even then the Demons are a nice subwoofer. Heard a pair of those in the 10" locally Monday afternoon on around 1,200 watts and for a sealed...
HI all - I don't have a windows machine and thus can't use WINISD, so I've been playing with speakerboxlite.com Can someone cross-reference this...
fakename
fakename
earth
fakename
GoldCountryCA
    Apr 26, 2024
GoldCountryCA
    Apr 26, 2024
