Anybody bi-amping front main speakers?
  • 4
bikejunkie223
Dls Wh0re
2,012
Salem, OR
Hey everyone,
I just got my new reciever Saturday (Denon 2106) and am sthinking about bi-amping my front mains (paradigm Studio 40's) because I am not doing 7.1 surround and have the extra channels of power. My question is, is it worth it, or should I leave it as it is? I already have them bi-wired, so it just means moving the wires and changing an amp assign in the menu. Opinions one way or the other please!
Bi-amping will actually make a perceptible difference, vs. bi-wiring...which won't //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Go for it if they're rated for the power.
I think they should be- the little manual that came with the speakers says they are bi-ampable, and they have the little straps that connect the terminals. I know bi-wiring makes no difference at all audibly- I just had the speaker wire laying around and did it. I'll probably need to readjust all the speaker levels after as well? Also where is a good starting point for sub crossovers? It's hard to tell where LFE info starts with home theatre (for me anyway)
I bi-wired my advents and it didn't do jack ****. If you don't have the power to do so, then you really shouldn't bother. There have been articles written on it and the gains have tradeoffs (most notably price).
You should adjust the sub x-over until you cannot tell you have a sub in the first place. The bass should just come from the speakers. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
If you can edit the EQ for each channel or other para's then the bi-amp would be a good idea, also if you are just looking to split the load then it would be good.
Actually, I was wrong, it was to go into his 1972 Currier! The 4runner just wasn't workable and he ended up getting a high performance motor...
28
3K
For a sub that small.. Id like to see an 8 or 6.5 @ around 55-70 htz usually sound pretty nice and clean on approx 40-100 rms @ 4 ohms. 8 ohms I...
8
PURE AMPLIFIERS | ADDICTIVE AUDIO, INC. (addictiveaudioinc.com)
bikejunkie223
Dls Wh0re
bikejunkie223
Salem, OR
joetama
Doxquzme
    May 10, 2024
3toneEYZ
    May 10, 2024
