As titled, the B2 is actually not the MKII, it is the newer quattro
I'm the 2nd owner of both that were just bought ~2 months ago. I'm stationed in Portugal right now and they were shipped to my wife in AZ. The both sit in the boxes they were shipped in.
The Zed Draconia II was bought from Vertex on here. It is brand new. It's in pristine condition with no marks on the plexiglass, even has he plastic still on it. There are no marks on the mounts, RCA's or the wiring connectors. Comes in original box with manual, CD and wiring. Cosmetically 9.8/10 seriously its brand spanking new, mechanically 10/10. Very powerful amp, Rated power is 175 watts x 4 into 4 ohm or 250w x 4 into 2 ohm.
Bridged power is 350w x 2 into 8 ohm or 500w x 2 into 4 ohm.
More Specs:
The pairs of channels are independently bridgeable.
Two or four input configuration.
Channels 1+2 feature 24dB per octave Linkwitz Riley High and Low Pass crossovers.
Channels 1+2 can run in FLAT mode (Pre-amplifiers completely bypassed), High Pass, Low Pass or Bandpass.
Channels 3+4 feature 24dB per octave Linkwitz Riley High and Low Pass crossovers.
Channels 3+4 can run in FLAT mode (Pre-amplifiers completely bypassed), High Pass, Low Pass or Bandpass.
Channels 3+4 in addition feature SUB MODE which introduces a 24dB per octave variable subsonic crossovers and a 40Hz constant Q equalizer.
Level controls accommodate input levels up to 8.0v RMS.
Pre-amplifiers utilize a fully isolated power supply for zero ground loops.
Pre-amplifiers drive the main amplifiers in a fully balanced mode.
Class D amplifiers utilize high-speed high current low gate charge MOSFETs.
Fully regulated power supply delivers power independent of battery voltage.
There are a total of thirteen regulated power supplies.
The power supply utilizes six 110 amp MOSFETs in a source follower configuration for maximum bandwidth.
Low ESR 105°C capacitors are used in the power supply.
Very high efficiency owing to the smart power supply.
Tiffany RCA's with Teflon inserts are used for ultimate quality and reliability.
Made in the USA
B2 Audio Quattro was bought from Cody at Droppin HZ Car Audio. Was used in a build he did for a few months and then pulled. Nothing mechanically wrong with it 10/10, there is some black stuff on the bottom of the amp, I'll try to get it off.
Specs
Power @ 4 Ω: 4 x 100, 350 x 2 bridged
Power @ 2 Ω: 2 x 150
$500obo shipped - Draconia
$250 shipped - Quattro
Only trades would be for a very nice 6 channel. One that can be displayed
Included
More Specs:
Made in the USA
Specs
Included
