Zapco refrence sq components built by esb
cal
ZAPCO RB-13.2 ITALIAN BUILT SQ BY ESB
nib, only opened for pics and hav ebeen stored in closet. these are the high end sq components made by esb in italy. these are qualitty built and haevy not the cheap i force one on ebay . these reatail for 700 and are salling on woofers for 459.00 im selling way below to move them quick . these were purchased from an authorized zapco dealer so no refurbs or junk .
http://www.woofersetc.com/p-4966-rb-132-zapco-525-reference-component-system.aspx
Specs:
5.25 component set
150 watts rms
Moving Coil resistance RE: 3.6 Ohms
Resonance Frequency FS: 74 Hz
Mechanical Q QMS: 5.62>Electric Q QES: 0.48
Total Q QTS: 0.44
Mobile Mass Mms: 10.09g
Mechanical Compliance Cms: 0.46 mm/N
Cone Diameter D: 10.5 cm
Surface Area Sd: 86.5 cm2
Maximum Volume Air Shifted Vd: 364 cm2
Equivalent Acoustic Volume: Vas: 4.81 liters
Moving Coil Inductance Le: .68 mH
Force Factor BL: 6.12 Txm
Max Linear Excursion X Max: 4 mm
Max Peak Excursion X Max peak: 13 mm
Carbon Fiber Cone
Die Cast Aluminum Basket
DLC Differentiated Shape Suspension
(Double Linear Control)
Y-35 Ferrite 18 Oz. Vented Magnet
Heavy-duty Extended-pole Magnet Plates
1.2" / 30mm Voice Coil with Kapton Former
Flat Profile Nomex Progressive Spider
24K Gold Plated Connectors
325.00 each set shipped con u.s.
no trades
refrences
http://www.caraudio.com/forums/itrader.php?u=1006316
you need them .//content.invisioncic.com/y282845/emoticons/eyebrow.gif.fe2c18d8720fe8c7eaed347b21ea05a5.gif
fwiw, the i-force set is still pretty damn good. But these are sex. Right there with any other boner set you want to throw out.
If these were 6.5's, I'd be all over them
dont really want to get into specifics about the i force but a dealer stopped selling zapco after they came out with the new line and went to hybrid audio, i agree tho these are some **** beasts and build quality is insane .
Well... I meant "for the price." Comparing them to HAT isn't really a fair fight.
fade,
i was not comparing them to the H.A.T i was just saying when zapco went to the new line the shop that carries the quality of the zapco refrence went to similar product the H.A.T .
LOL its like saying a ferrari is compared to a toyota
  • Locked
I dont see a Username and date on any of these pics that the FOR SALE Rules Should Apply. Are these pics off Ebay?? Place those with the pics so...
I follow a guy on YouTube called PS sound he's a high-end car stereo installer in the UK yeah I'm talking like super high-end cars and expensive...
10
I may get a pair of his 6" woofers for the back. It's an extended cab pickup so the enclosure won't be as bad as a door with holes in it. Highs...
13
  • Locked
COMPLETED Zapco SX6 SQ
This Amplifier is Pending. Yet still available to purchase until sold.
cal
cal
cal
    Jun 15, 2024
    Jun 15, 2024
