ZAPCO RB-13.2 ITALIAN BUILT SQ BY ESB
nib, only opened for pics and hav ebeen stored in closet. these are the high end sq components made by esb in italy. these are qualitty built and haevy not the cheap i force one on ebay . these reatail for 700 and are salling on woofers for 459.00 im selling way below to move them quick . these were purchased from an authorized zapco dealer so no refurbs or junk .
http://www.woofersetc.com/p-4966-rb-132-zapco-525-reference-component-system.aspx
Specs:
5.25 component set
150 watts rms
Moving Coil resistance RE: 3.6 Ohms
Resonance Frequency FS: 74 Hz
Mechanical Q QMS: 5.62>Electric Q QES: 0.48
Total Q QTS: 0.44
Mobile Mass Mms: 10.09g
Mechanical Compliance Cms: 0.46 mm/N
Cone Diameter D: 10.5 cm
Surface Area Sd: 86.5 cm2
Maximum Volume Air Shifted Vd: 364 cm2
Equivalent Acoustic Volume: Vas: 4.81 liters
Moving Coil Inductance Le: .68 mH
Force Factor BL: 6.12 Txm
Max Linear Excursion X Max: 4 mm
Max Peak Excursion X Max peak: 13 mm
Carbon Fiber Cone
Die Cast Aluminum Basket
DLC Differentiated Shape Suspension
(Double Linear Control)
Y-35 Ferrite 18 Oz. Vented Magnet
Heavy-duty Extended-pole Magnet Plates
1.2" / 30mm Voice Coil with Kapton Former
Flat Profile Nomex Progressive Spider
24K Gold Plated Connectors
325.00 each set shipped con u.s.
no trades
refrences
http://www.caraudio.com/forums/itrader.php?u=1006316
Specs:
5.25 component set
150 watts rms
Total Q QTS: 0.44
Carbon Fiber Cone
no trades
refrences
