zapco c2k and jbl gti crown comparison
trunks9_us
well i know zapco is most likely better since i run zapco and all but i was wandering how the the sq quality on the jbl gti amps i was looking into a gti 6000 but i dont know how good they are sq wise compared to a zapco 9.0 of course the gti 6000 is alot louder but i can always get more 9.0s anyways plz feel free to comment about the gti series. and the comparision.
i would easily run eaither depending on the size limitations of the installation. also if you want you can do that symbalink shit with the zapco. basically its balanced RCA system.
but as far as build quality, i would put them both at the top with the zapco slightly above the gti, but the gti is less expensive per watt, and the GTi is more flexible with any resistance, whereas the zapco does power at 2ohm mono, but the zapco is 2 channel and thus flexible as well where the gti is mono only.
so there are benifits to both. the GTI is DEEP as hell, and the c2k is long as ****. so really its all on prefrence. both look very much like ****** explosion.
//edit
http://www.zapco.com/prod/comp_prods/c2k90Frame.htm
zapco c2k 9.0
Suggested Retail $ 3473.00
bridged 2 ohms 1x2200wrms
2 channel
$1.6\w
http://www.cardomain.com/item/JBLA6000GTI
jbl gti crown 6k
Our Price: $5999.95
6000 watts RMS into anything from a 4-ohm to a 1-ohm
mono
$1\w
/edit
HI SQUEAKR!!!
http://www.jbl.com/car/products/product_detail.aspx?prod=A6000GTI&cat=AMP&ser=GTI
SPECIFICATIONS
General
CEA Rated
Click here to learn about the new CEA2006 Amplifier Standard.
Power Output2600 Watts RMS x 2 channels at 4 ohms
and ≤ 1%THD+N
8110 Watts RMS x 1 channel at 4 ohms,
14.4V supply and ≤ 1%THD+N
7400 Watts RMS x 1 channel at 1 ohm,
Signal-to-Noise Ratio65 dBA (reference 1 Watt into 4 ohms)
Dynamic Power6854 Watts at 4 ohms
Effective Damping Factor6.39 at 4 ohms
Frequency Response10Hz to 270Hz (-3dB)
Maximum Input Signal8.5V
Maximum Sensitivity250mV
Output Regulation.2 db at 4 ohms
Dimensions (H x W x D)6-1/2" x 29-3/8" x 23"
trunks9_us
trunks9_us
college station tx
xtremebassjunky
