Zapco amp wattage
audi1031
Posted up like a MAILBOX
I have a 2- zapco amps and its the reference 750 and looking at the specs it reads
Stereo 4 ohm: 2x175 watts
Stereo 2 ohm: 2x375 watts
bridge 4 ohm: 1x750 watts
T.H.D + noise
s/n ratio>95 bd
slew rate>40v/us
Damping factors >1000@4 ohms
My question is that it does not show what the Wattage would be for 2 ohm load bridge. Does anyone know what it would be. The reason I am asking is that I have 4-4ohm 15's and wanted to know what the best way to hook these up as if i should go bridged with 2 on each zapco or should I go with stereo 2 ohm at 375 watts and if i do the second option how would that happen as it does not give specs for 2 ohm load at 1 channel... Thanks I really appreciate it
I have a 2- zapco amps and its the reference 750 and looking at the specs it readsStereo 4 ohm: 2x175 watts
T.H.D + noise
s/n ratio>95 bd
slew rate>40v/us
Thats because its not 2ohm mono/1 ohm stereo stable
Using those amps and all 4 4ohm drivers you wont get more than 175rms to each.
In this scenario I much rather just run 2 drivers with a bridged amp on each.
but the speakers have just one hook up on the speakers. This was odd as I though all dual voice coils or speakers with 8 ohms will have one set of and dual ohms will have 2 one per coil. I have been away from stereo stuff a while now but I am back
audi1031
audi1031
austin Tx
audi1031
