Sold Zapco 350.2 for sale or trade
R05Nismo
PA
I have a Zapco Reference 350.2 for sale or would like to trade for a sub amp that does around 500rms at 2ohms mono. Let me know what you got.. I prefer quality amps like.. (must be made to run at 2ohms mono)
Zapco Reference 500.1
JL Audio 500/1
Phoenix Gold Ti800.1
Arc Audio
Etc...you get the point
The amp is in very good shape for being used. Works perfect, very powerful for only a 350 and most of all this amp is CLEAN!! One of if not the best i've ever heard.
$250 shipped in the lower 48 with insurance and tracking number.
I do have the owners manual and the birth sheet. Tested power is 394. This would make a really nice amp for a set of components or lower power sub.
Stereo, 4 ohms: 100X2
Stereo, 2 ohms: 175X2
Bridged, 4 ohms: 350X1
T.H.D. + Noise:
S/N Ratio: >95dB
Slew Rate:>29V/uS
Damping Factor: >200 @ 4 ohms
Dimensions: 15"L x7.5"W x 2"H
-SymbiLink™ Balanced Inputs
-RCA Unbalanced Inputs
-2 ohm stereo stable
-18 dB variable bass boost
-Built in variable electronic crossover
-Bridgeable
-Three channel capable
-High Current Bi-Polar output devices
-Optically isolated MOSFET power supply
-Switch for use as stereo, single L ch. or R ch. bridge
-L+R Sum Mono switch for use as bass amp
-Surface mount technology w/1% resistors,
precision caps, and massive ground planes
-Quality ZAPCO construction
** Designed and Engineered in the USA **
Suggested Retail $597.99
This is from Robert at Zapco.
Let me say it like this.
If its used product we will service it. NOT UNDER WARRANTY THOUGH of course. It must have all serial number in tact. Also know that we trace every serial number that comes into this building and question anything out of the ordinary. Like the post says you need to watch out for Grey goods from Canada because those will not be serviced in the US. As far as questions....the one thing we are being really strict on is the DC product. The DC line is more hands on so we will recommend going to a authorized dealer. There is far to much to try and explain espically if we have to start from 1. Our dealer are here for a reason. I have found a few customers dealers to work with and things tend to turn out just fine.
So there is no warranty for used gear.
Didnt mean to post dump, Im still interested.
Would you take 225 shipped for it.
I just copied that from the site, didnt catch that. I took the part out about the warranty. Yes I would take 225 shipped but if your from Zapco could we work a deal for a Reference 500.1?
Nismo is a great guy to deal with. I recently just bought a Zapco 200.2 from him and it looks almost brand new.
Thanks man, I really dont want to get away from the Zapco brand but need an amp that will make around 500 at 2 ohms. (Like your Zapco 500.1 //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
that ti600 in your avatar does 600+ and stable at 2 ohm, can't you use that?
Thats what i'm going to do if this amp don't sell. PG Ti on the sub and Zapco 350 on the front stage. I plan to keep the stock battery/alt so I just wanted an amp that was made to run at 2 ohms so it didnt pull as much current and put the 600 on my front speakers.
heres some specs
2 x 270W @ 4ohms
2 x 525W @ 2ohms
1 x 1050W @ 4 ohms bridged
THD:
Freq. Response: 20Hz ∼ 20kHz
S/N Ratio: 105dB
Damping Factor: >2000 (1kHz)
Max. Current Draw: 135A
Fuse: 3 x 30A
Dimensions: 18" x 8" x 3.35" (45.7cm x 20.3cm x 8.5cm)
and it does about 1150 at 4ohms
heres some specs 2 x 270W @ 4ohms
2 x 525W @ 2ohms
THD:
S/N Ratio: 105dB
Fuse: 3 x 30A
Is it not made for 2 ohms bridged? 18 inches is a tad long too, it has to fit under my seat.
R05Nismo
R05Nismo
PA
somegreekguy
