zane, need help with alpilne splits...
  • 2
Generally they are designed for free - air applications, however can produce better sound in some cases in a sealed enclosure.
In order to determine the enclosure volume, I will need the T/S Parameters for these speakers.
SPL(sensitivity)
Qts
Qms
Qes
RE
Fs
Vas
BL
take it easy,
-zane
thanks zane.
Unfortunately I am unaware of the various parameters of the alpine splits. As they were given as a gift, there is no packaging. I might be able to go to my local car auido shop and find out more specs (they were unexperienced with enclosures/ enclosure volumes). Until then, I do have more info on them that may or may not help. The info I found in the latest full line catelog made by ////ALPINE. Here they are.
Model: SCS-1756
Type: Component 2-way
Peak Power: 150watts
Nominal Power: 50watts
Freq Resp: 45-22,000hz
Sensitivity: 90db
Install dia:140mm
Depth:60mm
Magnet weight: 226g
hope you can find ANY of this useful and thanks for your help!
well thanks anyway zane, could you even come up with a rough estimate size box for a 6 inch speaker like this component. I am going to be using this pair as replacement speakers for my 4ohm home stereo (in bedroom) instead of the crappy pioneer numbers with their 7mm chipboard boxes.
(p.s. should i bother playing around with ports for better bass as i have an unlimited supply of MDF-joys of being a son of a cabinet maker)
again, ANY help is greatly appriciated
i done some research and found the parameters. here they are:
SPL: 91dB/W/m
Qts: 0.51
Qms: 4.4
Qes: 0.57
Re: 3.5ohm
Fs: 52hz
Vas: 0.93 cubic ft (26.2 litres)
Bl: ?
cone area: 132.7cm
voice coil dia 25mm
driver physical volume: 39.7 cubic inch (0.65 liters)
Hope you can find this info useful, and again thank you very much for your help!!!!
338
297
668
542
If you can find these in your area. Id recommend these for drop ins. They play from 40Htz on up. Sound very nice on amplified power for premium...
vxcoupe_300
vxcoupe_300
Australia
vxcoupe_300
Brendon Jenness
    May 8, 2024
    May 8, 2024
