Zane! & other electrical gurus, I need some help please!
  • 2
borborygmi
I'm connecting my amp to my head unit with Monstercable Interlink 201XLN RCAs. I need to cut one end so I can splice it into my factory harness in my trunk (leads to my head unit for the HU outputs) and the other end of the RCAs will plug into my amp. These RCAs are 'balanced' with a (+) & (-) for each channel. Here's my question, Monstercable has a 'drain' wire running the length of the RCAs, where do I connect this wire when splicing into the factory harness?
TIA
sorry i cant answer your question but i would suggest that you do NOT cut the monster cable rca cord. buy a short (less expensive) male to female rca cord and cut and splice that.
because the monster cable was probably very expensive and if you make a mistake when splicing you would not want to have to buy a whole new monster cable (or reinstall it) just because you messed up the last 6 inches. plus when you upgrade the HU you will have an "intact" monster rca cable to use in the future. thats why.//content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Subs play to the beat with gain low but if I turn it up my subs play loud unwanted never ending bass that is constant and wont stop until I turn...
You have a blown cap in the amp more than likely. Had the same thing happen to a soundstream amp.
230
No need to bypass the amp. Most use an LOC that takes the full amped signal and turns it into a flat RCA level signal. Here is the newest I have...
433
borborygmi
borborygmi
San Diego, CA
borborygmi
Decebal
    Jun 10, 2024
