Your db Numbers!
Vehicle: 98 Ford Explorer (fathers truck)Electrical System: Stock alt, walmart battery, and some 2/0 wire.
Amplifier(s): (1) Orion 2500D (powered at 2ohms)
Subwoofer(s): (4) 12" MTX 7500's
Box: about 9cubes tuned to 40hz.
Mic: New TL
Song/Tone Played: 48hz
db Result: 147.3
was alittle upset cause i couldnt get the Orion to stay stable at .5:(
the goal was before I sell these subs is to hit 150's. I guess i may have to buy another amp to do so:(
try a dual chambered, SMALLER box with 4 aeroports out of the box firing at the back and the 12s firing up. also, get your note up to 51hz. That equipment is easily capable of a 150 in that vehicle. try rolling the volume up as well instead of a straight burp, that may give you enough impendence rise to get more power out of the amp than a straight burp since the electrical system cant keep up with a straight burp.
ditto on the rolll...
I ran the 2500d on stock alt and one battery no problems at .5.
oops, double post...
wheeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee //content.invisioncic.com/y282845/emoticons/peace.gif.2db28b618ed8d1964ebbe2f5021d2c39.gif
x2..as a matter of fact, i do it daily, factory alternator, red top battery. even just a straight burp...
impedence rise in my enclosure means i'm getting max spl at 52-53hz @ 2ohms..lol..so i do a 144.4 with an s18x off 1700wrms from my orion 2500d (outlaw, new tl) wired to .5 nominal..hence the amp change i'm doing thrusday...
anyway, back on topic, the orion is more then capable of .5ohm stability, as the previous ppl have mentioned, and as i prove daily...lol
think i have a lemon? lmfao
I hear and read i can get it to .5. but everytime i try it doesnt stay
Only will go for about a 4 sec burp, then go into protection
I feel maybe im drawing to much
think i have a lemon? lmfaoI hear and read i can get it to .5. but everytime i try it doesnt stay
well you only need a 3 second burp for spl, so whats the problem //content.invisioncic.com/y282845/emoticons/naughty.gif.94359f346c0f1259df8038d60b41863e.gif
hit me up on aim and ill help you get that explorer louder
lol...yeah..a 3-4 sec burp is good...
what settings are u using..i wonder if ur overdriving it somehow? ever notice what ur voltage is dropping too?
i've only ever had mine shut off twice...at 9 volts...lol..
wheeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee //content.invisioncic.com/y282845/emoticons/peace.gif.2db28b618ed8d1964ebbe2f5021d2c39.gif
I can tell You that 1 Orion 2500D @ .85'ish dcr will draw upwards of 320 amps @ full tilt with a lil' clipping.
Two of these amps (one per coil @ .85ish) off of two Blue Tops will start out @ 14.6 vdc float and end @ ~11.2 vdc after 4-5 seconds.
-Nick
how my amp is set
got this right from Shane
how my amp is set
id turn that sub-sonic filter off and let all the crap come through...and why does a non-strappable amp have a master/slave switch //content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif
You can still link the gains so that a pair will match. I have heard that you can still strap them if you know what you are doing. I am not sure how true that is though,.
ss3079
Eh Dere Hi Dere Ho-ser
ss3079
Up North
bgowdy
