Yellow top or Kinetic
Depends on the way your battery holder is. I use threaded stock to make my brackets. 1800 would be my choice but if you start going bigger I would add a hc1200 to the back. Its a good idea to a battery in back when you start getting into higher power situations.
An 1800 would be good but I would recommend putting something in back like an HC1200 when you put your 4 channel in. Kinetiks are flat sided so you would more than likely need to mod the tray.
What Kinetik Power Cell(s) do I need to purchase? Kinetik makes choosing a Kinetik Power Cell simple. Our model numbers are equal to the wattage needed for your vehicle. For peak performance and maximum lifespan of all electrical equipment in your vehicle simply add up the total wattage needed for all of your aftermarket equipment including all amplifiers, lights, winches, video and other electronics. The Kinetik Power Cell model number designates the amount of wattage it will be able to run. For example: your aftermarket system includes a 300 watt amplifier, a 200 watt amplifier and 40 watts of additional lighting. You have a total of 540 watts of additional power so you can run this system on a single HC600. If you are replacing your factory starting battery with a Kinetik Power Cell, you should factor in 800 to 1200 watts aproximately to run your factory equipment as well. If your stock alternator is 90 amps your factory electronics use around 1224 watts (90 x 13.6 volts). So adding an aftermarket system of 540 watts to your factory needs of 1224 watts would be 1764 watts of power needed. In this case we would recommend purchasing a single HC1800 or higher. If you plan to purchase additional electronics, you may want to factor them in as well. Remember you can always use more than one Kinetik Power Cell in your vehicle, adding addtional Power Cells at a later time is always an option.
that was just taking a fast look.
Is this a rebuttal? This statement makes no claims which support you saying 100aH per 1kw.
kingkung
kingkung
Huntington Beach, Ca
lostdaytomorrow
