XXX and HOA?
the nine.1s are terribly efficient, i had a avionixx 800.4 (almost the same amp), it was awesome, very little dimming with 1100wrms.
its the tripath circuitry
I'm running a BX1500D (~1350 RMS) with my XXX and I don't have any dimming with my stock 120 amp alt. Although my distro block says 14-14.1 volts at idle, and with the rpms revving. But when I am bumping it goes down to 13.6-13.7. Is that bad or normal?
I have a I pushing around 700-800 watts to 2 jl 10w6s and i'm dimming. I have a Ford F250 SuperDuty. You guys are LUCKY! So amps have a lot to do with dimming? Different amps won't dim at same wattage?
Yes, partially. Dimming is based on your current draw - some amps that are more efficient (like Class D, T, or X) will draw less current for a given power. Some, like Class A/B, will pull more current for the same amount of power.
+1 My friend!
I'm running an Elemental Designs NiNe.2 bridged (400w RMS) and I'm dimming pretty good in a 2004 Saturn Vue. I think it's dimming mainly because I used to be an idiot and sit places with my car off and stereo on for 20-30 mins at a time so I pretty much killed my battery.
1400+ on my stock alt nothing. No dimming at all.
Buddys expo running around 1400+ dims when the bass hits heavy. He has the 5.4L engine so it is quite a beefy engine for such a small stock alt.
im powering my xxx15 with about 1300-1400watts, powering each infinity 6.5 mid with 60watts; electricaly everything was stock. had the big 3 and thats it. never had any dimming. this is all in a 98 accord with stock battery and 80-90amp alternator....go figure...now i have a red-top under the hood and a 170amp alternator incase i want to upgrade...but when everything was stock i never had anything close to dimming running that much power.
Repeat after me...deep cycle...
//content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Beermakesmehoppy
Beermakesmehoppy
Antioch, CA
Beermakesmehoppy
