2004alpinewhite
Ok, I have an xtant 604x and 603x.. just hooked them up to work with the imaging of the system i'm designing.. The 603x takes up to 100amp fuse, 604x takes up to 120amp.. I had them both on 150 amp fuses because its all I had at the moment, but the 603x said that it was over current, so I took them both and hooked them both up to one 150 amp fuse.. So they are capable of handling 220, but are only getting 150, yet the over current protection light on the 603x is still on?!? It makes a buzzing sound when its turned on?? the amp itself! i turned them off imediately and checked all the wiring but I really dont' know what the hell is up?!? Any one know how to fix this problem? If its over current that means it has to be coming from the power wire, right??
