Xtant 603
What kind of deal are you getting? That amp is nearly 10 years old. If memory serves me right...the 3rd channel will put out roughly 300 watts @ 2 ohms (IMO, those subs need at least that amount per driver...I would recomend a single dual 2 ohm typr r for that amp).
$400.
Wow 10 years old? Did they continue making that model for many years? It was new in a box.
I need to power some infinity kappa fronts and rears and then a pair of 10" type R's Any recommendations? I'd like to stay close to $400 for amps if possible.
It's not going to have enough power on the sub channel for a pair of 500 watt subs.
Why is that? Do '500 watt subs' not turn on or something unless you hook them up to a 1kW amp? No...of course not. Those big Xtants have quite a bit of guts to them and sound a lot bigger than the specs lead on. The sub channel on that amp is more than enough for a pair of W6's and I see no reason why it wouldn't beat up a pair of Alpine subwoofers.
The thing I'd be worried about are dried out caps. You may pop a cap when it's first hooked up to power and you'll probably be SOL as far as a warranty goes b/c those amps are nightmares to repair and I highly doubt Mitek would service it.
If the amp works & there isn't a noise issue from the caps aging, I think you'll love it.
Obviously. Unless he's going to run a overly large box, that amp will not be able to push those two Type-R's to their potential, plain and simple. I've had that amp before, I know what it's capable of. And while they are underrated, I definitely wouldn't not try to push a couple of Type-R's with the sub channel. It had a hard enough time with a pair of old Assassins. More than likely he's going to clip it trying to get the output he wants with the 400-500 watts of clean power that he has available.
Thanks guys, I think I will go another way. My local dealer told me they were under rated but that does seem like a big difference.
Also the box is in the back of my jeep wrangler. It has 2 individually sealed .85 cubic inch slots.
if that amp is brand new that price is alright i found used ones for around 250, and a new one for $360 with shipping and that was just a quick search.
---------- Post added at 07:51 PM ---------- Previous post was at 07:50 PM ----------
XTANT 603X 600W 5 CHANNEL CAR AMPLIFIER CHROME FINISH. BRAND NEW | eBay
here is a new one bid on her you will probally win it for $240.
if thats the case i need to buy the one from my coworkers son then.
drakedog79
drakedog79
Traverse City, MI
sacsking916
vegang
vegang
