Sold XTANT 4.4 - near mint
Livin
$175 + actual shipping * Paypal or USPS Money Order accepted
Will consider trades for...
Gigabyte GA-P35-DS3R motherboard
NVidia 8400 or 8500 series video card
Sonic Impact T-Amp, or similar digital amp
Matching car speakers... 6.5 component set + 6.5 coax set
10" sub & sealed sub enclosure - made for the sub
my other Wanted/FS thread here
PM all offers (do not post it in thread) - please bump if you look.
VERY LITTLE USE
- sitting for a long time, since I changed vehicles. I decided not to put it in my new car.
- near mint cosmetics and perfect functionally
- amp only, no packaging or manual *you can get it online from xtant.com
Specifications:
Number of Channels 4
50 Watts per Channel 4 Ohm
100 Watts per Channel 2 Ohm
200 X 2 Bridged Mono at 4 Ohm
Distortion
Signal to Noise Ratio >100dB A-Weighted in 20KHz noise bandwidth @ 1 volt sensitivity
Damping Factor >100 @ 100 hz @ 4 Ohms
Frequency Response 20Hz-20KHz +/- 1 dB
Input Sensitivity 100 mV - 8.5V Unbalanced, 200 mV-17V balanced
Input to line output gain 0dB
Onboard Crossovers
Front High Pass 12 dB/Octave variable from 40-120 Hz
Rear High Pass 12 dB/Octave variable from 40-120 Hz or
Rear Low Pass 24 dB/Octave variable from 40-120 Hz
0-12 dB Bass boost @ 45 Hz
A.R.C. 0-15 dB level adjustment
Balanced line on-board
Operational Voltage 10-16V
Dimensions 15-9/16 L x 9-1/16" W x 2" H
Requires 60A Fuse
Features
Fully Regulated PWM Power Supply
N-Channel MOSFET Design
Defeatable Balanced Input
Active Resonance Control (ARC) (Found only in front channels)
4 Full Range RCA Outputs
Livin
Livin
Chandler, AZ
Livin
Mike Mccabe
