xluben @ kpozr2 meet. heres what comes out. PIC/VID!
kpozr2
good meet up to give him the box i made, sounded killa, got a vid, but need to put it on the comp, so this pic will have to do some justice until then.
Yeah, the one nearest the port is a little higher than the other one.
Didn't Mark Potts tell you? That adds a half a DB!
//content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
i tried to get them pretty well centered, but i put them in and screwed them down in all of about 3 minutes. i think it looks good enough for me!
last night i moved my amp from the top of the box to the side, and then it went into protect the next time i turned it on. i could not figure out what was wrong, checked all connections going into the amp, turned the car on and off a couple times and got nothing. today it dawned on me to check the connections to the sub box, and they must have gotten pulled out when i moved the amp, so all is well again //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
and my buddy puked out the rear passenger window and it's all over the side of my car, so i need to get a carwash today!
so do they sound allot better in a ported box xluben? i wish i had a car so i could try it.. my truck just doesnt have a trunk : (.. i am almost ready to buy 2 10's just so i have the space for a ported enclosure..
is your x600.1 doin the job?
yeah, ported is the way to go, but i did lose almost all of my trunk space. why don't you just take your back seat out and put them each in 3 ft^2 each tuned to 28Hz and hit some REALLY low bass? //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
i called of aaron from PG and he did verify that even if the birth sheet says 6xx (mine says 615W) that just means it's an old birth sheet, and they all were reworked and will do just over 800W. mine really pounds, but i have to set the gains high (higher than my DMM says i should //content.invisioncic.com/y282845/emoticons/crap.gif.7f4dd41e3e9b23fbd170a1ee6f65cecc.gif) and it also seems to run a little hot (but not nearly as hot as my profile amp), i just expected it to stay cold with the 'variable speed fan cooling' and such //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
and the assassin's have had no problems taking 400W each in a ported box! when i was setting the subsonic filter i accidentally set it to the lowest setting (5Hz) instead of the highest setting, and played a 20Hz tone full volume!!!!!! the subs were flopping like sheets in the breeze, but they came out of it fine (after i realized what i had done i was quite scared). i'm pretty sure i got to witness way more than 15.5mm of one-way excursion //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
that f'n back seat would be history, except i have 2 children that sit back there..
but the 10s only need 1.2 cuft chambers for a ported box, so i could pretty easy make a box for 10s with ports.. but no way 12s.. 2.4 cuft is all i have..
How old are the kids? //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Could you extend the box into the footspace a bit (along the floor)? Or maybe in the middle (and get an extra cubic foot)?
I e-mailed Chad from AA, and he said 3.5 cu ft would be fine, and I could even go a bit smaller if I needed to.
I bet if you just extend the box in to the middle area of the foot space you could get enough volume to do them ported //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
i could do one ported easy.. i have had the idea of buying one aresenal 12 and building a single 12 box ported.. with room to spare.. the only reason i am thinking arsenal it can take 750 rms so the pg x600.1 would work well with it..
would 1 arsenal 12 in a 2 ft^3 ported box be louder then 2 assassins in a sealed box? i know it would be lower, but would it be as loud or louder?
if so i think i have 2 assassins for sale..
kpozr2
kpozr2
Iowa CIty, IA
jasperpso
