CrAiZ3
Hi guys! Looking to trade for a good SQ setup. Let me know what you have! I'm looking for something that does well at 4 cubes or smaller, and has a good bit of punchy bass. Also, I will part out but prefer to trade my setup for both good sub(s) and an amp. You pay shipping for my stuff, I pay shipping for yours.
Will also trade for professional grade DJ equipment.
Audioque HDC318 D2
Condition:
Mechanical 10/10 (never had a problem with it)
Cosmetic 8/10 (normal wear)
This thing has been my baby and kept in great condition. I'll be sad to see it go
Kinetic HC2400
Condtion:
Mechanical 10/10 (worked fine and held a charge last time I touched it. Has been sitting around for about a year)
Cosmetic 7/10
Fusion Powerplant PPAM200010
Condition:
Mechanical 10/10 (never blown a fuse or had any problems)
Cosmetic: 8/10
Bass Boost @ 45Hz: 0-12db
Frequency Response: 20Hz - 350Hz
Fuse Rating 40amp x 3
Input Impedence: 20k
Input sensitivity: 0.2v - 8v
Max Power Rating: 2000w
RMS Ratings Per Channel:
600 x 1 @ 4ohms
900 x 1 @ 2ohms
1000 x 1 @ 1ohm
Variable Low Pass Filter: 6db / Octave
Dimensions: 436mm(L) x 278mm(W) x 60mm(H)
Amplifier Class: Class D
Variable LPF (35Hz-350Hz)
Crossover Selector Switch
Output RCA Terminals for Daisy Chaining audio signal
Diecast Diamond Cut Endcaps
45deg 4AWG Angled power terminals
If you are around the Pittsburgh area, I will gladly meet up if you would like the box as well (it's pretty darn big). It's late right now but i'll get some newer pictures up tomorrow of everything.
Audioque HDC318 D2
Condition:
Kinetic HC2400
Condtion:
Cosmetic 7/10
Condition:
Cosmetic: 8/10
600 x 1 @ 4ohms
900 x 1 @ 2ohms
1000 x 1 @ 1ohm
