WTT:Soundstream XXX-4000d
chromecity
Up for trade is a like new Soundstream XXX-4000d. I upgraded to more power a few months ago so this has just been sitting in my closet collecting dust. Looking for just about anything since I'm getting a new truck in a few weeks. Will also sell outright... Still have the origional box, bass knob and paperwork.
New pic with username:
what did the birthsheet say as far as ratings? and I am still interested in your alt. Im waiting on a reply to see if I wanna go bigger like 350 amps or not.
The amp came with no birthsheet. But I can post specs. This amp is also stable at 1/2ohm. I had it running my dd9918f in a Tahoe and did a 148.7 on the termlab with a stock alt and one svr 3500 battery in the back.
Does the amplifier work perfectly?
How about an Orion 2500D Chrome series?
Might add some moolah or another amplifier on my end too.
Hey you are in Salisbury, I live a little North of you but am up here for school at the moment.
LMK,
Ronny
RMS Power @ 2 Ohm, 14.4V: 2200
RMS Power @ 1 Ohm, 14.4V: 3300
RMS Power @ 1 Ohm, 16V: 4000
Total Harmonic Distortion: 5.00%
Frequency Response: 15-150Hz
Signal-to-Noise Ratio: 80 dB
Damping Factor: 350
Signal Voltage: 500mV-10V
Potential Current Draw: 280A
Dimensions: 2.625"h x 11.375"w x 22.125"L
Low Pass Filter: 18dB, 50-150Hz
Bass Boost: 0-18dB, 45Hz
Subsonic Filter: 18dB, 15-40Hz
Phase Control: 180°
Gunmetal finish w/ brushed accents
Non-regulated mosfet pwm power supply
Three-way protection circuitry (thermal, short,
impedance)
Twin stack technology TM(strap amps together
for double power)
Delayed on/off circuit
Variable low pass crossovers
Variable bass boost
Variable subsonic filter
180 O phase control
Pre-amp outputs
Dash mount remote gain control
Direct wire 0 ga. Power, 4 ga. Speaker terminals
how did it actually preform? did you ever bench it? what kind of electrical did you have backing it? also any guts shots? also a pic with username would be smart...i mean we all have to do it and youre brand new with 29 post...id think that was a given...or even a small video showing the amp works 100%
This amp has an unlimited power supply so the more voltage you run to it the louder it gets. I had it running at 13.4 at 1/2 ohm and it ran great!
No, it was never benched. Like I said, at the time I was running 1/0 stinger wire, a 300a fuse a diehard platinum up front and a svr 3500p in the back with the amp. I havent used siince I purchased my incriminator 40.1... I can post pics with username in just a few. These were my ebay pics.
hey guys I have two of these amps, one in the car and one waiting to go in. They are made to be run 16v out of the box, are rock solid and are strappable. I'll be happy to answer any questions if the OP cannot. FYI I am running four SoundStream T5 10's on one @ 1 ohm, and will be strapping two together for .5 each.
Mine connected just fine, but I liked the onboard menu better and deleted the app.
45
Very true statement here. Can also possibly damage the subs if not used properly,and may even cook an amplifier in the process possibly. It may be...
chromecity
chromecity
Salisbury, MD
chromecity
GoldCountryCA
    May 5, 2024
GoldCountryCA
    May 5, 2024
