WTT Sony Xplod 600 watt 2/4 channel amp
4/3 Channel GTX Series Car Amplifier
RMS Power Rating:
4 ohms: 60 watts x 4 chan.
2 ohms: 70 watts x 4 chan.
Max Power Rating:
4 ohms: 110 watts x 4 chan.
2 ohms: 150 watts x 2 chan.
Bridged, 4 ohms: 300 watts x 1 chan.
Max power output: 600 watts x 1 chan.
Pulse modulated MOSFET power supply
LED power (green) and protect (red) indicators
Soft Start Turn-on
4/3 channel operation
Speaker-level (high-level) inputs with signal sensing for automatic turn-on
Heavy duty aluminum alloy heatsink for extreme heat dissipation
Gold-plated RCA level inputs
Gold-plated screw terminals
Input sensitivity:
Low level: 0.3V-6V
High level: 2.8V-12V
Variable high-pass filter (80 Hz, 12 dB/octave)
Variable low-pass filter (80 Hz, 18 dB/octave)
Frequency response: 5-50,000 Hz
Signal-to-Noise ratio: 100 dB
THD (Total Harmonic Distortion): 0.05%
Dimensions: 10"D x 14-3/4"W x 2-1/4"H
(Taken from Sonic Electronix website)
-Chris_Bretz-
-Chris_Bretz-
Sevierville, Tennessee
-Chris_Bretz-
