does it run that on 12 or 14 volts?1200 @ 4ohm1700 @ 2ohm
2500 @ 1ohm
will do a hell of a lot more at .5 ohms, but wouldnt run daily for hours at that. you would need to make a major improvement on your electrical.
well last truck i did was a bedcut with 4 cutting edge 15's, 3 optima yellow tops, (2) 2.5 farad caps, ******* the life out of the vehicle maxed hitting, running 11.8-12.6 jumping and was putting out a little over 2600-2640.....If you can upgrade the electrical and maintain at least 14-16 you can really produce with these amps. I dont reccommend .5 ohms unless you can maintain 13.5-14 MIN....does it run that on 12 or 14 volts?
well im looking for an amp to run a solo x 12" at 1ohm daily so im thinking just keeping my electrical between 12-13 voltswell last truck i did was a bedcut with 4 cutting edge 15's, 3 optima yellow tops, (2) 2.5 farad caps, ******* the life out of the vehicle maxed hitting, running 11.8-12.6 jumping and was putting out a little over 2600-2640.....If you can upgrade the electrical and maintain at least 14-16 you can really produce with these amps. I dont reccommend .5 ohms unless you can maintain 13.5-14 MIN....
