WTT My Atomic 10in AP/SPLs
stuckinok
Sick My Duck
I want to trade this things as i have already changed my mind on my new set-up. The subs are in great condition. I got these from TheLow about a month ago but i dont want to run my ZX2500.1 @ 1ohm nor do i want to find a new amp. I would like to trade for 6.5in components, deep cycle batts, DD subs or motors, maybe a SPL 15 and some beefy 8s.... pics can be found in this thread.
http://www.caraudio.com/forum/showthread.php?t=273333&highlight=atomic
I will take up to date pics if there is some intrest in these monsters
SPECS These are underrated at 1000wrms but can be burped up to 4000!!!!
* APSPL 10, Available in DVC 0.7, 1.0, 1.4 and 2.0 ohms
* Rigid Die cast aluminum basket.
* Organic long fiber non-pressed cone body for accurate tight bass.
* Curvilinear Kevlar reinforced cone body .
* Extended neck joints on cone, coil and spider strengthen the integrity of moving structure for high power capacity.
* Butyl rubber surround heavy duty and forever lasting.
* Compressed mounting ring gasket.
*Vented coil for extra heat dissipation.
* 2-1/2 inch high temp aluminum voice coil.
* Extended, machined cut one piece back plate.
* Powerful 1 inch thick 90 oz high energy magnet.
* 2-1/2 inch long excursion motor structure.
*Reinforced resin impregnated polycotton spider extend the life span of the speaker from material fatigue and collapse.
*Integrated heavy duty lead wire on spider prevent short circuit and melt down.
Thanks
Jose
even if Rd audio's main building burnt to the ground, and everyone including Steve Miller and the entire staff were horribly burned to death in the fire......you could still call SJA for a recone.
and FYI I got a recone the other day as a spare from RD with no issues....so //content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif on that logic
iam glad that you had a good transaction with them but if you do a search on the company a couple bad threads pop up...... but i guess the same can be said about any company but whatever i am not dissing the product just moving with caution.
stuckinok
Sick My Duck
stuckinok
Rio Rancho, NM
stuckinok
