WTT: Minty D9 For Sub/Amp Combo
CL1CKCLACK
CarAudio.com Boss
So heres the official thread that many of you dumped in in the thunderdome. Bought this amp from a good friend of mine before i realized i was going to have to buy a car, and wouldnt be able to afford a sub and wire... So now my baby has to go. This amp does not have a single flaw, not even the normal marks around the mounting feet. My buddy spltuscon bought this amp new and babied it. The amp never saw low voltage and was only wire below 1 ohm for short burps.
As far as trades go im looking for quality equipment. Meaning no crap, must do rated, and must do it cleanly? if thats a word. Looking to get a 2-3k Amp, and a 15 inch sub to go with it. If the deals right, it can be a straight trade. But would prefer a small amount of cash with the deal...
Lol and if anyone needs specs...
Digital class-D linkable mono block amplifier
MOSFET PWM power supply
Daisy-chain through output RCA
Heavy duty cooper layer double sided epoxy PCB
Stable into 1 ohm and 2 ohm parallel amplifier connection availability
24 dB low pass (LPF) crossover variable
18 dB bass boost equalization control variable
180 degree variable adjustable phase shift
24 dB subsonic filter variable
Selectable Switch for MASTER and SLAVE Operation
Speaker short, over current, thermal, and DC protection circuit
RCA line input and line output
2 x 0 guage (AWG) battery input connectors
Efficiency: 86% at 4 ohm, 100 Hz
Tested voltage & THD : 14.4V and less than 1% THD at 4 ohm RMS watt
Operating voltage: DC 10V ~ 18V power input
Damping factor: better 350 into 1 ohm
Wired remote controller
Specifications
RMS power, 2 ohm linkable/dual mono
RMS power, .75 ohms mono 5400
RMS power, 1 ohm mono 3600
RMS power, 2 ohm mono 1800
RMS power, 4 ohms mono 900
Signal to Noise Ratio >100dB
Low pass frequency crossover 35Hz~300Hz
Subsonic filter 10Hz~60Hz
Bass boost @ 45Hz 0~18dB
Phase shift control 0~180 degree
Frequency response 10Hz~350Hz (+/- 1dB)
T.H.D @ 4 ohm
Efficiency @ 4 ohm 86%
Fuse rating 500 amps
Input Sensitivity 200mV to 6V (+/- 5%)
Onto the pics.
CL1CKCLACK
CarAudio.com Boss
CL1CKCLACK
Land Of The Hicks...
CL1CKCLACK
