SimplyStryking
1. Product: Hifonics Zeus ZXi 1010
2. Specs:
Zeus ZXI 2-Channel AB Car Amplifier
RMS Power Rating:
4 ohms: 250 watts x 2 chan.
2 ohms: 500 watts x 2 chan.
Bridged, 4 ohms: 1000 watts x 1 chan.
Max power output: 1000 watts
Ultra-Fi MOSFET power supply decreases distortion and produces high fidelity
Wired remote bass level control included.
LED power/protect indicators
Bass Boost: (0-10 dB bass boost at 45 Hz)
Soft start sound
2/1 Channel operation
Preamp RCA outputs
RCA level inputs
Screw terminals
Heavy duty aluminum alloy heatsink and vents for uncontested heat dissipation
Built-in system diagnostics protects from short circuits, over load, thermal over-heat and DC offset
Crossover selector for high pass, full range or low pass operation
Damping Factor: 200
Variable high-pass filter (10-150 Hz, 24 dB/octave)
Variable low-pass filter (30-150 Hz, 24 dB/octave)
Subsonic filter and level control
Frequency Response: 10-30,000 Hz
Dimensions: 15-3/4L x 9-1/2W x 2-5/8H
4-gauge power and ground wiring is required for installation. Contact us for information regarding a discount on select amplifier kits when purchased together with this amplifier.
Description/Condition: Condition i'd say 8/10 no dings, couple scuffs on end caps, No box, bass knob, missing 2 set screws on speaker outputs (bought without and ran bridged so never picked any up). mechanical 10/10 works great, never had an issue with it.
4. What you are looking for: component set or a head unit better than a deh-3200. Obviously i will add cash for whatever, just tell me what you got
2. Specs:
RMS Power Rating:
Soft start sound
Preamp RCA outputs
RCA level inputs
Screw terminals
Damping Factor: 200
