WTT for In Dash Nav unit
eatank
I have the following for trade.
Soundstream D'Artagnan 5.1 Amplifier . I bought and tested it and everything worked perfect. Comes in the original box. 400.00
D'Artagnan 5.1 RUBIT (Rapid-Use Branched Impulse) Proprietary power supply topology STACTT (STabilized Apex Current Topology) Reduces power supply stress by 50% Auto High CurrentT Matches the amplifier for virtually every load application ChassisinkT Transistors are located between circuit board and heatsink for optimal heat dissipation Variable Input level controls for exact input match to amplifier Continuously variable 24dB low-pass crossover (40Hz to 220Hz) Continuously variable 12dB high-pass crossover (50Hz to 200Hz) Hawkins Bass ControlT Proprietary bass equalization topology Harmonic Bass AlignmentT Produces tighter and more accurate bass reproduction Continuously variable subsonic filter (13Hz to 30Hz) TridentT amplifier protection topology IDIT (Intelligent Distress Indicator) gives visual conformation of protection status Balanced Line inputs for the highest level of noise rejection Platinum RCA input and output Platinum 4 gauge power inputs 10Hz - 30 kHz frequency response >100dB S/N ratio 0.02% THD 6 Channels RMS @ 4 ohm 65 x 5 + 200 x 1 RMS @ 2 ohm 100 x 5 + 400 x 1 RMS @ 1 ohm 500 x 1 (sub only) Dimensions: 19" x 11.5" x 2.25
SFPD2PT (2) 15.00 A PIECE Midi digital fuse block
SANLFH0WPT (1) 30.00 ANL fuse block
swkh4(1) 50.00 a piece Wire Kit 4 gauge
SWCKH44(1) 110.00 Multi 4 gauge Wire Kit with Cap included
SFB1MAX (1) 7.50 Maxi fuse block
SBT428NPT (1) 15.00 battery terminal
SBTR28NPT (1) 10.00 battery terminal
SGT4N (1) 5.00 ground terminal
PROBATT8 (3) 5.00 A PIECE 8 gauge PRO Ring terminal
PROBATT8PT (2) 5.00 A PIECE 8 gauge PRO Ring terminal
SGMSA (1) 17.50 Stinger's new SGMSA provides two 7/16" bolts for use with existing GM battery cable (one standard length, one long), one 7/16" bolt for use without the GM cable, and one bolt for use on Stinger’s Power2 batteries (in place of existing terminals). The SGMSA is 24K gold-plated and has distribution outputs for one 1/0 gauge, one 4 gauge, and two 8 gauge wires. Works on either positive or negative battery terminals.
SCSK1 Nitrus CAP (3) 75.00 shipped a piece
I can send you pics on request. This stuff is all bnib.
FS Eigervision EVP-104DH
This is a brand new in box top of the line product. Asking price is 750.00 OBO. Retail on this unit is well over 1500.00
Eiger Vision’s newest addition to a great line of “Great Entertainment” is the EVP-104DH, a 10.4” all in one CD/DVD/MP3 combo unit. Don’t let the compact size fool you! Eiger Vision has ‘Super Sized’ the Combo Features. They include a High Definition, Low Reflection TFT/LCD 10.4 inch Monitor, 16megabite Anti –Shock Buffer Memory, Dolby Digital 5.1 (AC-3 Decoder/DTS Digital output), 2 RCA Composite A/V Input’s, Dual RCA Composite A/V Output’s, Integrated TV Tuner and 2 Dome lights. With the user friendly built-in IR Transmitter for Headphones, Remote IR-Receiver with a Full Function Remote, Selectable FM-Transmitter for Audio, Front panel Operation, Dual-Zone A/V Switcher and ON Screen Display of all functions!
“This compact combo unit is a must-have for any serious ‘Great Entertainment’
BNIB underbody Multi Color kit. Does all sorts of visual effects. Strobe,all kinds of stuff. 150.00 bnib plus shipping. Pics upon request. Here is an explanation of it.
http://www.amazon.com/exec/obidos/ASIN/B0007U0G9S/nextag-ce-20/ref=nosim
Will trade everything for the right unit. That is a heck of deal if some one wants to make some cash...
eatank
eatank
shingle springs,ca
eatank
michigan born
    May 14, 2026
michigan born
    May 14, 2026
