WTT / Feeler: Eclipse 55090 HU
dru
What I have is a Eclipse 55090 HU (retail $1600 but of course I'm not looking for that value in a trade and that was several years ago) and I'm looking for another Eclipse HU; I can't use this HU and I'm sure someone else can make use of its DVD capabilities. Possibly looking for straight up trades or selling it for cash so I can buy another HU.
THx for your time
dru
edit: I do have the remote but the battery cover is missing. I can also attempt to find the manual //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif.
CD/DVDSECTION
Maximum output level: 5.9 volts
Frequency response (20 to 20,000 Hz, referenced to 1,000 Hz): +0.0, -1.4 dB
Channel separation: at 1,000 Hz, 87.2 dB; at 20,000 Hz, 74.1 dB
Dynamic range (A-weighted, referenced to 0 dB): 91.6 dB
S/N ratio (A-weighted, referenced to 0 dB): 92.7 dB
THD plus noise (with 1,000 Hz): at 0 dB, 0.015%; at -20 dB, 0.045%
LINEARITY ERROR (at -0 dB): +0.8 dB
INTERCHANNEL PHASE ERROR (at 20,000 Hz): 1.3 degrees
DE-EMPHASIS ERROR (at 16,000 Hz): 0.05 dB
MAXIMUM DEFECT TRACKING (with Pierre Verany Digital Test disc): 1,500 micrometers
TUNERSECTION
All measurements for FM only, except for frequency response.
MAXIMUM OUTPUT LEVEL (100% FM modulation): 3.6 volts
ADJACENT-CHANNEL SELECTIVITY: 15.1 dB
ALTERNATE-CHANNEL SELECTIVITY: 70.2 dB
CAPTURE RATIO (at 65 dBf): 2.5 dB
USABLE SENSITIVITY (mono, 75-ohm input): 13.6 dBf
50-dB QUIETING SENSITIVITY (mono, 75-ohm input): 22.1 dBf
CHANNEL SEPARATION (at 65 dBf and 1,000 Hz): 39.6 dB
THD PLUS NOISE (at 65 dBf): mono, 0.61%, stereo, 0.72%
S/N RATIO (A-weighted, at 65 dBf): mono, 69.1 dB; stereo, 66.0 dB
AM REJECTION (at 65 dBf): 63.1 dB
IMAGE REJECTION: 66.0 dB
FM FREQUENCY RESPONSE (30 to 15,000 Hz, referenced to 1,000 Hz): +0.8, -0.5 dB
AM FREQUENCY RESPONSE (30 to 3,000 Hz, referenced to 1,000 Hz): +0.9, -9.1 dB
39011 SURROUND PROCESSOR
MAXIMUM OUTPUT LEVEL: 7.7 volts
FREQUENCY RESPONSE (20 to 20,000 Hz, referenced to 1,000 Hz): +0.0, -1.2 dB
CHANNEL SEPARATION: at 1,000 Hz, 72.8 dB; at 20,000 Hz, 76.3 dB
DYNAMIC RANGE (A-weighted, referenced to 0 dB): 99.9 dB
S/N RATIO (A-weighted, referenced to 0 dB): 97.6 dB
THD PLUS NOISE (with 1,000 Hz): at 0 dB, 0.02%; at -20 dB, 0.03%
D/A LINEARITY (at -90 dB): +0.6 dB
INTERCHANNEL PHASE ERROR (at 20,000 Hz): 1.2 degrees
The Eclipse 55090 DVD tuner turned in good bench numbers. The CD section had good output level, a good S/N ratio, low distortion, and good D/A linearity. Its frequency response had a mild 1.4-dB rolloff at the high end. Its tuner section was slightly better than average, with good S/N and selectivity numbers and good FM frequency response. I wished FM distortion had been slightly lower, but it was about average for head units. The 39011 processor had similarly good performance, with good S/N and distortion figures. No problems here. —KCP
dru
dru
Blacksburg, VA / Chesapeake, VA
dru
BP1Fanatic
BP1Fanatic
