WTT: Diamond amp for
kombat96
trying to get a game system PS3, Xbox360, then a wii. will add cash i have refs and have other audio items such as wire kit 0ga, sub, and a few other things if someone is interested. PM guys:p:
Diamond Audio Amp D5 1200.1 brand new FORSALE 225 obo
how much would you sell for? whats the specs @ 2 ohm?
Class D Mono Amplifier Topology
• Pulse Width Modulated (PWM) MOSFET Switching Power Supply
• Extruded Aluminum Heatsink
• Double Sided Gold Plated PC boards
• Nickel Plated Panel Mount RCA Low Level Audio Inputs
• Nickel plated, low resistance power and speaker connector blocks
• Power ON and Protection LED Lighting for Easy Diagnostics
• Thermal, Short Circuit, and Overload (Low Impedance) Protection
• 12 dB bass boost
• Chassis mounted ATC/ATO type automotive fuses
• High Current Output Capability (2 or 1 Ohm)
• Internal 24dB/Octave Low Pass Filter (50-250Hz)
• Bass Boost EQ (0 to +12dB) at 50Hz
• Remote Level Control for Dash Mounting
• Intended for use on subwoofers
RMS @ 4 Ohm 450 Watts x 1
RMS @ 2 Ohm 800 Watts x 1
RMS @ 1 Ohm Mono
1200 Watts x 1
Crossover LP
THD
Frequency Response
20 - 250 Hz
Length
16.3 in. (414 mm)
Width 9.6 in. (245 mm)
Height 2.9 in. (74 mm)
cash price asking 250 + actual shipping. no other hidden fee's
kombat96
kombat96
michigan
kombat96
