slammedincouch 10+ year member
1. Product:
Few things up for trade:
1.) (4) DC M3 8s (Trading As "Blown" Please Read the Description)
2.) Digital Designs 9012 (D2)
3.) Digital Designs M1c
4.) 15" DC LVL 5 M1 (D2)
5.) Kicker KQ30
6.) Digital Designs C1b
2. Specs:
1.) DC M3 8s:
2" Copper coil
600watts rms (Full Specs: DC Audio - m3 8)
2. DD 9012
3" Coil
OS TC Basket
Sub is from 2001
1000 watts rms (Full Specs: http://web.archive.org/web/20010609171839/www.ddaudio.com/9kSeries.htm)
3.) DD M1c
Rated for 1200 watts at 11.9, 1700 @ 14.4 (Full Specs: M1c | DD Audio)
4.)LVL 5 M1:
3" 8 layer coil
"2k" rms
5.) Kicker KQ 30:
Pre-Amp/30-Band Graphic Equalizer
Center Frequencies (at 1/3-octave intervals)
Bass: 25Hz-80Hz
Midbass: 100Hz-320Hz
Lower Midrange: 400Hz-1.27kHz
Upper Midrange: 1.6kHz-5kHz
Treble: 6.4kHz-20kHz
Cut/Boost: +/-12dB
Signal-to-Noise Ratio: >95dB, a-weighted, 1V ref.
Input Sensitivity: 500mV-9V
Output Level: 0V-9V
Stereo/Mono Operation
6.) DD C1B:
60watt x 2 @ 4 Ohm
100watt x 2 @ 2 Ohm
1 x 200watt @ 4 Ohm Bridged
3. Description/Condition:
1.) M3 8s:
Bought the subs off a friend like this. Only one coil on each side reads, which leads me to believe the leads were burned on one side of each sub and need to be reattached. Have not attempted to fix nor do I plan on it (will be sending them in for recones if the LVL5 gets traded for an amp), so i'm just going to say they're blown in their current condition.
2.) DD 9012
As stated the sub was manufactured in 01. 8.5/10 cosmetically, 10/10 mech. Oldie but a goodie. Had it in the explorer for around 6 months on the m1c feeding it around 1300 watts.
3.) DD M1c
8.5/10 cos, 10/10 mech. Have had the amp since Feb 2013, has never seen below 12.4 volts. Previous owner scratched a few and bent up one of the mounting feet, other than that she looks great. Have Bass knob, but not the original box.
4.) DC LVL 5 M1
9/10 cosmetically, 10/10 mech. Has only seen 1500 watts from previous owner and 1600 watts from me. Coil is still shinny as the day I got it. Have posted this multiple times with no interest, and she's in the explorer currently, so if you are interested in coil pics and dmm readouts on the coils, please just let me know and I'll get them with time and date. Otherwise I'll save my back and arms from lifting her out again
5.) Kicker KQ30
10/10 Cos, 10/10 Mech. Bought it to use in an active setup, never ended up using it and it's just sitting here collecting dust.
6.) DD C1b
10/10 Cos, 10/10 Mech. Bought for tweets amp in the active setup, used it in the passive setup, then bought a JL 300/2 for a little more power for the passive setup.
4. What you are looking for: :
Looking to trade for a 2k+ amp (Sundown, DD, DC, etc) and either a pair of w7s, beastly pair of 12s or 15s (Tantric, zv3s, zv4s, etc) maybe a pair of 18s and so on. Subs need to wire down to 1ohm. May also be willing to sell outright (But would prefer to trade), just pm me what you're interested in and a BO figure I guess. Please let me know if you need anymore info or pictures.
5. Pictures of your item for trade:
1.) M3 8s
2.) DD 9012
3.) DD M1c
CONTINUED IN NEXT POST
5.) Kicker KQ30
2. Specs:
1.) DC M3 8s:
2" Copper coil
2. DD 9012
3" Coil
OS TC Basket
Sub is from 2001
3.) DD M1c
4.)LVL 5 M1:
3" 8 layer coil
"2k" rms
5.) Kicker KQ 30:
Bass: 25Hz-80Hz
Cut/Boost: +/-12dB
Output Level: 0V-9V
6.) DD C1B:
60watt x 2 @ 4 Ohm
100watt x 2 @ 2 Ohm
1.) M3 8s:
2.) DD 9012
3.) DD M1c
4.) DC LVL 5 M1
5.) Kicker KQ30
6.) DD C1b
1.) M3 8s
2.) DD 9012
3.) DD M1c
