wtt audio stuff for xbox 360 stuff
lilkman2202
I have 100ft bnib stinger hpm 16awg
a set of PB s6c components bnib
14 1-2ft 1/0 wire
hammer crimper
1 1/0 fuses holder
4 fuses 250s and maybe 1 300
1 custom built tc9 12" sub
looking for a hdd for my xbox 360, games, controllers,
a decenet spinning reel and decent baitcasting reel
whats the specs on that 12. gotta 20gig HDD, xbox, 2 controllers, and a few games. inculding black ops. also have a used turtle beach x3 to go with it and the xbox cam thingy.lol
Resko1:
Theres not a single drop of ca glue on these either. Built completely with grey rubberized epoxy as compliant with tc sounds oem.
I added a polypropylene stiffing ring on the extended former for added strength and stability at high excursion. Also helps keep them linear. Single stiff spider, alum round coils that are .02" wider on od then the oem coils. Rms would be about 1500ea. Coil xmax is 23mm oneway.
Here's T/S parameters
12" ultratech blue monster
Taken in series
FS-31.63hz
QMS-4.862
QES-.5244
QTS- .4733
VAS- .9161cuft
RE-3.729ohms
LE-5.123mH
Zmax-38.31ohms
CMS-.07mm/N
MMS-370g
BL-22.87tm
SPL-83.84db 1W/1M
Resko1:Theres not a single drop of ca glue on these either. Built completely with grey rubberized epoxy as compliant with tc sounds oem.
Taken in series
FS-31.63hz
QMS-4.862
QES-.5244
QTS- .4733
VAS- .9161cuft
RE-3.729ohms
LE-5.123mH
Zmax-38.31ohms
CMS-.07mm/N
MMS-370g
BL-22.87tm
SPL-83.84db 1W/1M
u gots pics?
lilkman2202
lilkman2202
Milwaukee, WI
lilkman2202
