Wtt AB VFL 150.1
Austinw88
1. Product:
American Bass VFL 150.1
2. Specs:
2900@1
* I OHM STABLE D CLASS MONO BLOCK AMPLIFIER * LOW LEVEL INPUT AND OUTPUT * FREQUENCY RESPONSE: 20Hz~350Hz * INPUT LEVEL: 0.2V~6V * VARIABLE SUBSONIC: 10Hz~50Hz AT 24dB/OCT * VARIABLE LOW PASS FILTER: 35Hz~250Hz AT 24dB/OCT * VARIABLE BASS BOOST: 0~9dB AT 45Hz * REMOTE GAIN CONTROLLER * TWO AMPLIFIERS LINKABLE CONNECTOR AND SELECTOR * FUSE RATING-200 AMPS, LINKED FUSE RATE, 400 AMPS * EXTERNAL FUSES AND FUSE BLOCKS * 2900 WATTS RMS * Width: 9.5" * Height: 2.25" * Length:16"
3. Description/Condition:
In great condition, no major scratches all set screws in good condition
100% working
I do have the bass knob
8/10 Cosmetically because it is used and has some small scratches
10/10 Mechanically
4. What you are looking for: :
something with less power around 1500-2k@1
plus cash on you're end depending on what it is.
5. Pictures of your item for trade:
WILL POST PICS WITH USERNAME IN THE AM!!!
Austinw88
Austinw88
South Carolina
Austinw88
