wtt 21" DP'S SUBS
cal
1. Product:
incriminator audio death penalty subs
2. Specs:
• 8 Spoke Black Cast Basket
• 3" Heavy Gauge 4 Layer Flat Aluminum Voice Coil
• Triple Black Progressive Spiders with Woven Tinsels
• High Pressure Kraft Fiber Reinforced Cone
• Multi-Layer Foam Surround
• Double Stacked Wedge Magnets with Black Nickel Finished Top and Bottom Plates
• Interlocking Aluminum Spider Spacer Assembly
• CILD - Center Interlocking Dustcap
• ADC - Air Driven Cooling - Six Column Vents for Max Motor Cooling
• S.T.A.R. Motor Design for Built in Motor Cooling
• Nickel Plated Push Terminals
• Wrap Around Rubber Gasket (not available for 21 " subs)
• 1500 watt RMS Rated
• DVC 2 ohm
3. Description/Condition:
used fully working . no mechanical issues or damaged foam /surrounds.
4. What you are looking for: :
smaller subs, amps, and cash
local deal unless u are willing to drive and pick the subs up . i live in ADDISON,IL 60101
cal
cal
cal
