WTT 2 DC Audio Level 3 12'' with Level 4 coils for 10'' sub\s
cman0655555
[FONT=&amp]1. Product: [/FONT]
[FONT=&amp] [/FONT]
[FONT=&amp]2 DC Audio Level 3 12'' with Level 4 coils[/FONT]
[FONT=&amp] 2. Specs: [/FONT]
[FONT=&amp] Key Features [/FONT]
[FONT=&amp] [/FONT][FONT=&amp]• Extremely rigid non-pressed paper cone assembly[/FONT]
[FONT=&amp] • Multilayered polymer foam surround[/FONT]
[FONT=&amp] • Polypropylene dust cover with embossed DC logo[/FONT]
[FONT=&amp] • 8” OD semi cup progressive roll spider[/FONT]
[FONT=&amp] • Extra heavy duty interweaved tinsel lead wire[/FONT]
[FONT=&amp] • Cast aluminum black frame[/FONT]
[FONT=&amp] • FEA analyzed and optimized motor assembly – Fully CNC machined[/FONT]
[FONT=&amp] • Rubber mounting gasket[/FONT]
[FONT=&amp] • Chrome spring loaded push terminals [/FONT]
[FONT=&amp] • Dual 4 ohm 3” Hi-temp Aluminum voice coil wound on black anodized voice coil former[/FONT]
[FONT=&amp] • Rubber magnet cover[/FONT]
[FONT=&amp] Level 3 12" [/FONT]
[FONT=&amp] Mounting Depth - 6.75" [/FONT]
[FONT=&amp] Mounting Hole Diameter - 11''[/FONT]
[FONT=&amp] Motor Width - 6.5" [/FONT]
[FONT=&amp] Weight - 20lbs [/FONT]
[FONT=&amp] VC Diameter - 3"[/FONT]
[FONT=&amp] Magnet Weight - 17.5lbs[/FONT]
[FONT=&amp] Power Handling RMS/Peak - 1000rms with these level 4 coils (Stock coil is 600rms)[/FONT]
[FONT=&amp] Impedance - D 4ohm[/FONT]
[FONT=&amp]Sd - 2 494.00 cm^[/FONT]
[FONT=&amp] Vas - 74.15 L [/FONT]
[FONT=&amp] Cms - N 2.17e-04 m/N [/FONT]
[FONT=&amp] Cas - 2.29e-07 m^5/N 1.16e-06 m^5/N [/FONT]
[FONT=&amp] Mms - 145.73 g [/FONT]
[FONT=&amp] Fs 32.9 Hz 28.3 Hz 26.2 Hz [/FONT]
[FONT=&amp] Bl - 22.18 N/A[/FONT]
[FONT=&amp]Re - 5.89 ohm [/FONT]
[FONT=&amp] Le - 5.06 mH[/FONT]
[FONT=&amp] Qms - 8.11[/FONT]
[FONT=&amp] Qes - 0.59 [/FONT]
[FONT=&amp] Qts - 0.55 [/FONT]
[FONT=&amp] Xmax - 22.5 mm [/FONT]
[FONT=&amp] Sensitivity - 86.40 dB[/FONT]
[FONT=&amp] [/FONT]
[FONT=&amp] [/FONT][FONT=&amp]3. Description/Condition: [/FONT]
[FONT=&amp]The right sub in the pictures is the better sub of the two it is a 9/10 basically flawless other than it is used. Have less than 5 hours of total playtime on it. Bought directly from dc.[/FONT] [FONT=&amp]The sub on the left is 100% functional just has a very small tear in the surround. It was fixed with ca glue directly from dc and has been ok since. I would say it is a 7/10.[/FONT]
[FONT=&amp] [/FONT]
[FONT=&amp] [/FONT][FONT=&amp]4. What you are looking for: : [/FONT]
[FONT=&amp]Only trades I am looking for is a set of nice 10's such as FI SSDs Q, SSA icons zcons , Sundown Z Series or similar style subs. No 12s 15s or 18s have no use and can’t fit them.[/FONT]
[FONT=&amp]5. Pics[/FONT]
Tear in the surround
cman0655555
cman0655555
Carlisle, KY
snyderd758
